Hi again:
I am having trouble using the text box.
Even after entering text manually (typing it in as I go), or importing it from Word, it is not possible for me to get to the beginning once the length of the message has gone past the text box. In other words, I cannot get back to the beginning of the text to change it.
Is there a way to do this?
Navigating in the Text Box
dbuxton
- Einsteiger
Re: Navigating in the Text Box
Problem solved!
The up and down arrow keys will work in the text box.
