Hewllo:
When I return to my pc after an absence and "wake it up" I am getting this message:
"Warnungen 40
Die datei ______ kann nicht geladen werden"
Can someone please tell me what this is about, and how to fix it.
Many thanks.
						PhotoAlbum or ?
Re: PhotoAlbum or ?
Translation:
Warning 40
The file ______ can not be opened
I am sorry but I do not know what that could mean. I never had this message. Are you sure that this message is from the software PhotoAlbum? Do you use this software or are you using the DiaShow?
							Warning 40
				dbuxton
 - Einsteiger
Re: PhotoAlbum or ?
I am (was) using the Photo Album
						Re: PhotoAlbum or ?
when a PC returning from 'Stand by' or hibernation mode, some programs (as well as some drivers) may have problems to return correctly to their former state. Probably Photalbum (or any other currently running program) couldn't open a temporary file it was using before going to sleep. Best way to avoid this is to save your work and close the program before leaving the PC alone for a longer time. Especially to save your work is very important
Regards, Jürgen
						Regards, Jürgen
