Sehr geehrte DiaShow-Anwender,
ab heute steht im Kundenlogin - http://login.aquasoft.de - die DiaShow 6.4.03 zum Download bereit. Diese Version enthält kleine Korrekturen, die Sie in der Versionsgeschichte nachlesen können.
Huch, wo ist Version 6.4.02? Diese Version gab es nur als "DiaShow für YouTube". Diese Version behob das Problem, das bei einigen Nutzern der Upload nicht funktionierte.
DiaShow 6.4.03 verfügbar
- Steffen Binas
dbuxton
- Einsteiger
Re: DiaShow 6.4.03 verfügbar
Hi all:
nicht sprech deutsch
Are there any forums in english?
Will the download page be translated into English?
Not complaining - I bought the program knowing there might be a problem knowing that I did not speak German - but hoping there will be more english available.
Thanks.
Thanks.
Hi,
you can switch the downloadpage to english at the top of the page with the "language"-button:
http://www.aquasoft.net/slideshow_en.as
AFAIK the forum is only a german forum.
Ralf
Ralf
Hi dbuxton,
if you have problems using the software just ask in english language. My english is not the best but I will try to help you.
Hi dbuxton,
1.
I do not know what you mean with "slide". You can delete a text or photo object by marking it in timeline or list and then you hit the delete key on your keyboard.
2.
If you import text without line break the text will be imorted as one long line and you have to insert the line breaks by hand. The text is not broken automaticaly in the slideshow.
You should open a new thread for each problem you have. Now you did insert your problems in an announcement of Aquasoft.
1.
2.
leider kommt bei dem link oben die versiongeschichte von 7.x
Gruss Burki
- Steffen Binas
Link ist korrigiert.
